Diamond Audio SX black SX124 12" SQ 600W RMS
  • 2
trumpet
Barry Schanz
Diamond SX black SX124 12″ Subwoofer
NIB
Everywhere you look on the new Studio series subwoofer you see some form of metal creatively used to improve performance. From the artfully designed O2 Cast aluminum frame basket to the unique heat dissipating radial heat sink, Studio subwoofers are built for sonic quality and speed. Featuring dual mirror image flat spiders attached to a dual 3″ four layer voice coil applied into an intercooled motor design with vented pole piece ensures that Studio subwoofers can handle the power.
  • Power handling: 600W Nominal
  • Total diameter: 12.4 in. (315 mm)
  • Mounting diameter: 11.1 in. (281.9 mm)
  • Mounting depth: 6.2 in. (157.5 mm)
  • Sealed enclosure volume: 0.875 ft3 (24.8 liter)
  • Vented enclosure volume: 1.25 ft3 (35.4 liter)
  • Hard anodized aluminum alloy cone
  • 02 Cast aluminum frame with aluminum radiating heat sink
  • Dual 4 Ohm 3″ four layer voice coil
  • Intercooled motor design with vented pole piece
  • Dual mirror image flat spiders
$249.95
$30 shipping, UPS Ground
We got Diamond Audio after the "D" subs were discontinued so I can't answer that. I was informed that the SX subs are, at least externally, identical to the D6 subs. The TX subs, which are mid-level, are completely new.
I had some of theyre subs and components in the past in the late 90s. They were nothing special and were expensive. I had better luck with Bostons...
38
The siq amps are Sq beast as well. And much cheaper. Made by s&I in Korea iirc
303
trumpet
Barry Schanz
trumpet
St Cloud, MN
trumpet
    May 16, 2024
    May 16, 2024
