Deck to match my system?
cake to install, it's typically just a little box. And you can find really really cheap ones for under $10 I think. but quality worthwhile ones tend to run above $50 I think. never used one myself, lemme see what I can find.
These should work, never done it myself so hopefully someone more knowledgeable can jump in.
http://www.sonicelectronix.com/item_27392_PAC-LD-10.html There's a really cheap simple one, typically fine if you just want to add a subwoofer.
Then we get into better quality ones with multiple channels so you can add amps for your speakers as well.
http://www.sonicelectronix.com/item_31818_VIBE-Audio-DELTABOX.html
http://www.sonicelectronix.com/item_34643_Alphasonik-PLD40E.html
yeah i got Gbob2003 to help me. he's helping me with all my projects. so with a LOC a pair of r series alpine components and either an apsm4080 or a Cadence XAH250.2 i should be able to hear my music over my sub? all on 4 gauge.
Sub set up is an oa 15 on a apsm 1300 tuned to 27hz at 2.9 cubes. 4 gauge wire.
The LOC won't make a difference what you can hear, it's just a way of getting the signal to the amp. You should be able to hear it just fine. I'd go with a stronger set of components to get at least 100w each side, but that's just me. I have 1200w on my single SA-10 and have 150w running to each component set up front.
Mr.meyhem
Mr.meyhem
Cold as F***, MN
TheUnderFighter
BP1Fanatic
BP1Fanatic
