Deck Is Not Powering On!! Pleeze Help
christopher0825
Okay, here is the problem, I have hooked up my pioneer Deh-4900 to my 2001 malibu, and when I got ready to turn it on, nothing happened!!!! I know which wire from the car is the +12volt constant, but I don't know whether to hook it up to the battery wire (yellow) or the ACC wire (red) help please!!!! Thank you!!!
u need to connect both the yellow(constant) and red(switched accessory). if u know which one is constant hook it up to the yellow one, and find the wire that gets power with the key on accesories. or u can just connect both to the constant but u'll have to manually turn off the unit everytime u exit the car.
also all your presets will be reset every time you turn the car off. just to make sure the deck is good connect the deck (red/yellow) to car (hot) and deck ground (black) to car (chassis ground)
christopher0825
christopher0825
Atlanta,GA
wite2nr
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
