xxBURT0Nxx
Team Ramrod
Okay so I have a 2000 VW Jetta, stock bat. and alt. I have kicker 0 ga ran to the back where it splits at the distro to 2 4 ga wires. one of the 4 ga wires isn't hooked up to anything, the other is hooked up to a kicker zx350.2 Now my problem is that after about 10 min of the car being off with stereo running, my battery will die. I also have a lot of alternatorwhine when driving around. And I'm only running 350 wrms MAX. Do you think my battery is bad and should be replaced (suggestions welcome) or is it the alternator or both. What about a bad starter. The lube on my starter causes it to stick making a wierd noise when you first start the car but then it's fine after that. Could that be the cause?
