DD's at a lower tuning???
I'm trying to get away from a wall, and stay below the window line. I also have to keep in mind that I have my air management in the back of the blazer too (tank, comps, etc).
How much space do you have to work with? about 6-8 cubes without going above the seats/window line?
Yup, that's about what I'm at. As for power, I have my 2 1211a (infinity's @ 2ohms), and a planet audio BB1350.1. I have 6 1508's, and I know they can take some power. I also know they can get loud without sacrificing space.
uh, why not just get another sub if you're so intent on low tuning?
Because I already have these sitting here. Also, I don't have the money to buy something else right now.
My 9512 sounds great and is tuned to 32hz.
This is the kinda input I'm looking for. Thank you. What size box & power are you using?
On DD's site, it (basically) says that they make the spiders stiffer to load the speaker as opposed to designing the box to load the woofers. It also says they design their speakers to play an octave lower then tuning frequency.
Also, DD's site says "Each Sub Series we make is designed to work in the DD Boxes." If you don't want to follow the companies suggestions, by all means, do whatever you want. It is not Audiobahn recommending these box specs, I think DD knows what they are doing.
If you do tune low I'd imagine you'd just sacrifice output for no gain in SQ. Only testing could find out if that would be true in your case though.
oxsign
No Affiliation
oxsign
Orlando, FL
dcole18
