dd help and pricing
corto
i am lookin very deeply in to dd subs. I was first going to get a 9500 15 in my trunk. I was told my loudiest set up would be 2 12s port facing passanger side .
i have a 95 avenger i could build a box in or make a box which would fit but i think that will be a task. Here is a picture of a trunk that looks like mine. Scroll down and there it is. what do you guys think my loudest (i/d) would be . I had 2 type r's before tuned to 32 off a directed 1500 and i loved it . What should i do
here is the link
http://www.caraudio.com/forum/showthread.php?t=146339&highlight=avenger+box
2`12's would theoretically be louder, but it depends on what you want to do
If you're atlking two of the same kind of subs nad have the cash go that way
I E two 9512's vs a single 9515, go with the 12's, but keep in mind the DD 9500/9900 series likes a LOT of juice to get movin //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
You'll be blowing your money if you get two 9500s of any size with just a 1500 to power them. If the amp makes 1500 @ 1ohm, get a pair of 2500s. The whole setup is based on how much space you have anyway. If you have the room for 2 12's then you should by all means use 2 12's. The pair will be louder on 1500w in a 5 cube box than a 9515 will be on 1500w in a 4 cube box.
Get 4 DD1010a's You'll blow the trunk off...They'd take about 6cuft total...counting port.....I've heard 4 DD1008a's ...Hit lower and louder than two Kicker L7 15's that were in a 5cuft ported box each...The 8's did it in only 5cuft total counting ports //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
corto
corto
Flint, Michigan, United States
corto
