DD Audio
You could run one sub instead of two and cut that airspace in half. Get a rough measurement of HxWxL and we can give you a better idea of what would work
You said it's going in a nissan titan? where do you intend on placing it, under the rear seat?
Yeah under the rear bench
---------- Post added at 01:14 PM ---------- Previous post was at 01:14 PM ----------
Yeah under the rear bench down firing
Theres not a lot of room under there. You're best bet is to have a custom ported box built for a single 10 or 12, or a custom sealed box for 2 10s or 12s. I'd say you have about ~2 cubes of space under there, but I've never seen the back of those trucks so I'm basing this off the kind of volume I had under my back seat of my silverado ext cab
Yeah it's not much room at all. But I'm actually having a guy off the forums design me a ported box for two 10's. And if he can make it work I'm probably gonna go with two Dayton HO's. I see alot of people run and recommend them for these types of setups
one sub ported vs 2 subs sealed, I'd say the sealed wont be too far off in output. The single 10 ported option is if he wants low lows, if not, then two sealed should sound good SQ wise and cone area should provide enough bump.
Well I've narrowd it down to a couple set ups but I'll let you guys know the end result soon
Papabiz
Papabiz
Great bend ks
Papabiz
michigan born
    May 14, 2026
michigan born
    May 14, 2026
