DD 4th order wall.
xtremebassjunky
Is it ever loud enough?
Ok, figured I would compile the previous thread...
It's still a work in progress... but it is getting better every chance I get to work on it...
As of the moment my vehicle is peaking at 24Hz, it was 32 for a while but I pulled the subs back out to strengthen the baffles and seal it a lil better as it blew the liquid nail out from before...
but... it also plays a 153.76 on the TL on the dash.... at 24Hz:crazy://content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I still need to add deadener to doors and a lot of fine tuning things... I havent done anything to smooth the front chamber up yet...
Vids:
hair trick:
I still havent got much vids of it after my voltage problem i had...
it's been a process as all big builds are... escpecially trying to do things right...
**updated: more vids
hair trick: http://s56.photobucket.com/albums/g1...t=M2U00023.flv
playing with can in window: http://s56.photobucket.com/albums/g1...t=M2U00025.flv
153.7 on judges db drag TL all sealed up at 24Hz: http://s56.photobucket.com/albums/g1...t=M2U00020.flv //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
my buddy masteryoda being lazy after we pulled out the subs the second time
test fits
part of my front stage
front stage amps, running active
my two alternators just for my m4's, compliments of gus at ohio... which by the way... I am the only person that I know of to get the alts to work like this in a 4.3 blazer... I e-mailed gus the instruction guide on how to do it if you want that info.
thank you. I am not done with it by any means... and I actually have plans already to tear out a lot and do something else this spring.
I am **** proud of my lil jimmy though for throwing out the numbers it is so far at such low frequencies... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
xtremebassjunky
xtremebassjunky
Charleston, SC, (Oklahoma)
xtremebassjunky
vegang
vegang
