UsAmpsFreak
Tantric? I've never even heard of that company.i'd go with tantric hdd subs then
wow ,then your in for a treat . i have them also .a little more than the dc xl subs ,but take lots more powerTantric? I've never even heard of that company.
Why not build a box according to what the woofers you choose call for ? And you could always bump up too 18"s as wellTantric? I've never even heard of that company.
Either way is great but with 10 cubes. I'd go 15s not enough air space for a set of most 18sWhy not build a box according to what the woofers you choose call for ? And you could always bump up too 18"s as well Level 5's on a m4a which does 7k not a m4 that does 5k ... Would be a great option ...
Hdd's from tantric are nice as well ..
Yes but unless a box is already made if he's wanting dc I was simply saying make a box to fit the chosen woofers ..Either way is great but with 10 cubes. I'd go 15s not enough air space for a set of most 18s
Yea I hear ya man But I think he said he had up to 10 ft to work withYes but unless a box is already made if he's wanting dc I was simply saying make a box to fit the chosen woofers ..Why say I want a 10 cube box and fit woofers accordingly doesn't make sense
Hey, first to Timmy i mentioned above that i have 16v batteries and a 390 amp alternator feeding them at 16v. So a M4 would be signifigantly more than 5000 watts, i've been told it'd be close to 7,000 watts at 16 volts. So i was thinking no real need to spend $1,000.00 to upgrade to a M4a as the difference in power wouldn't constitute the difference in money.Yea I hear ya man But I think he said he had up to 10 ft to work with
Didn't think you were. As your running a 16 volt system. And I did say to Timmy that you were working with 10 cubes of spaceHey, first to Timmy i mentioned above that i have 16v batteries and a 390 amp alternator feeding them at 16v. So a M4 would be signifigantly more than 5000 watts, i've been told it'd be close to 7,000 watts at 16 volts. So i was thinking no real need to spend $1,000.00 to upgrade to a M4a as the difference in power wouldn't constitute the difference in money.
Mylows> I don't have a 10 cuft box, i was simply saying that is roughly the size of a box i plan on building, but obviously it will be custom built for the woofers that i end up with. I'm installed on my own for 15 years, 7 of those in a high end, custom shop. I'm no newb lol
It's a truck with a camper on it so i could go pretty much as big as i need to, was just thinking of keeping it around 10 cubes so i'm not using the majority of the space.Didn't think you were. As your running a 16 volt system. And I did say to Timmy that you were working with 10 cubes of space
No I understand completely I'd stick with 15s then. If you want 18s you'll need a min of 6 cubes each sube. To do them justiceIt's a truck with a camper on it so i could go pretty much as big as i need to, was just thinking of keeping it around 10 cubes so i'm not using the majority of the space.
May be tricky running the dd amp that high. .. There built for 12v use and only up to 15vHey, first to Timmy i mentioned above that i have 16v batteries and a 390 amp alternator feeding them at 16v. So a M4 would be signifigantly more than 5000 watts, i've been told it'd be close to 7,000 watts at 16 volts. So i was thinking no real need to spend $1,000.00 to upgrade to a M4a as the difference in power wouldn't constitute the difference in money.
Oh? Hmm. My buddy works for them and told me it was fine to 18v, i guess maybe it's not posted in writing they are ok for it? Idk.May be tricky running the dd amp that high. .. There built for 12v use and only up to 15v
Are all of these upgrades, like affect the performance positively?.. or is it just preference with the carbon fiber and direct leads?carbon fiber cap or cone ,direct leads , stealth coil , ar surround
