DC Leve 6 m4 15 box size?
What's the recommend box size for the level 6 15? Word of mouth says 3.5, the site says 3.
Thanks.
i know people who use large boxes and some swear by smaller boxes. not to mention that the have several suspension options so that may be an issue too.
I sent my DATS over to a guy here and he tested his level 5s. I've been told and see plenty of installs where they use typical alignments....
you should try a few enclosures.guy here have 2 lvl 6s in 8 cubes per with a 4kw doing mid 150s..
He's been through 2 boxes so far. We'll see how this one does. He was getting a bunch of rise so we are trying to lower than some. Make the air flow a little better
yea typical of that design. just grab a pair of dual 1s and run the at 1/4 ohm. it will still rise to around 1.2. seen the exact same thing with the level 5 12s..
It was in a 6th order, his rear port was too small for the power of these woofers. He was getting too much rise from that I believe.
What frequency does he burp? Seems to me you could just go with a larger box than 3 cube if you're burping around 50hz you're not going to be hitting x-max unless he has 8-10KW on tap.
380
724
540
I have been attempting to study the true nature of why we tend to tune transmission lines and enclosures in general like we do, the nature of...
Go get some shitty wood or cardboard or something and figure out what the max is, play around with different dimensions to see what the max cubic...
23
Buck
little alien on campus
Buck
Inside of a pyramid
Papermaker85
    May 12, 2024
Brendon Jenness
    May 11, 2024
