Buck 5,000+ posts
little alien on campus
What's the recommend box size for the level 6 15? Word of mouth says 3.5, the site says 3.
Thanks.
Thanks.
i know people who use large boxes and some swear by smaller boxes. not to mention that the have several suspension options so that may be an issue too.What's the recommend box size for the level 6 15? Word of mouth says 3.5, the site says 3.
Thanks.
He's been through 2 boxes so far. We'll see how this one does. He was getting a bunch of rise so we are trying to lower than some. Make the air flow a little betteryou should try a few enclosures.guy here have 2 lvl 6s in 8 cubes per with a 4kw doing mid 150s..
yea typical of that design. just grab a pair of dual 1s and run the at 1/4 ohm. it will still rise to around 1.2. seen the exact same thing with the level 5 12s..He's been through 2 boxes so far. We'll see how this one does. He was getting a bunch of rise so we are trying to lower than some. Make the air flow a little better
So the guy wants his box less efficient?He's been through 2 boxes so far. We'll see how this one does. He was getting a bunch of rise so we are trying to lower than some. Make the air flow a little better
What frequency does he burp? Seems to me you could just go with a larger box than 3 cube if you're burping around 50hz you're not going to be hitting x-max unless he has 8-10KW on tap.It was in a 6th order, his rear port was too small for the power of these woofers. He was getting too much rise from that I believe.
guy on here i designed a box for 4 level 5s. he said it was ******..It was in a 6th order, his rear port was too small for the power of these woofers. He was getting too much rise from that I believe.
