Dc audio amp question.
That depends on your build. But a nice amp rack behind the box or even under the box can work
Ah you mean the custom shelf some people bed their amps in above the spare wheel right. Yes, that's what I've seen many do so I was surprised when you advised to maintain distance but you meant just not right next to it then...
I wouldn't even think about putting an amp with a big board like that on a box. Saw a guy at a show with an NS1 strapped to his box. He just let his system wang as he walked away. I pointed out to my buddy that the amp was flexing a stupid amount on the lows and was amazed he just let it get beat up like that. 10 minutes later the bass shuts off.. Amp in protect and never worked again lmao.
My box is the most sturdiest part on my truck. Everything flexes like crazy. Specially the floor of the truck. Once u get loud enough pretty much everything shakes so ur amps are gunna feel some vibration.. I've had my amps mounted to the back of my boxes for years now and no failures. I must be doing something right.
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
The 750 will give you better control at higher volumes as you won't be reaching clipping as soon..
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
FuckPeteCarroll
Vacaville, CA
Eggroll
