DC audio 2.0k
Bwap
NY
DC audio 2.0k
Bass knob with clipping indicator
DC audio 2.0k specifications:
Output Power (RMS) 4 ohm 14.4V 600W x 1
2 ohm 1,200W x 1
1 ohm 2,000W x 1
1 ohm@16v 2,500 x 1
Input Sensitivity 6V~0.2V
Low Pass Filter Switchable
( @ 24 dB Slope) Variable Hz 35~250
Subsonic Filter Switchable
( @ 24dB slope ) Variable Hz 10~50
Bass Boost Variable dB 0-9dB
Frequency Response Hz 15-270
Signal to Noise Ratio dB 100
Damping factor 150
Efficiency @ 4ohm % Over 90%
THD @ 4ohms Less than 0.1%
Fuse Rating 200 Amps
Linked Fuse Rating 400 Amps
Indicator Power Yes
Protection Yes
Clip Yes
Speaker & Power terminal Mold type power
Power Gauge size 0Ga
Heatsink Length inch/mm 17.72" / 450mm
Heatsink Width inch/mm 9.38"/238mm
Heatsink Height inch/mm 2.35"/59.6mm
Taking offers, not set on a price.
Will add for an mmats 3000.1 or 3000.05
Also add for a DC XL 15" or any quality 15" sub(s) that handle around 2k
For an estimate my zip code is 12053
got a 15" death penalty D1? imo its a better sub than the xl
are you near syracuse? are you familiar with TNESPL?
Havent heard of them, I am a little west of Albany in duanesburg. About 2 hours from Syracuse. Right now I have two dc lvl 3 15s.. running off this 2k.
I don't know what will beat that(researching a bit more), but im basically looking for something with a powerful motor.. debating buying an mmats 3000.05 and an xl with level 5 solf parts or carbon fiber option.. or maybe an aq hdc4.0.. idk yet minds racing on the new setup, im sure you know what I mean.
so im guessing your not interested in the DP. theres a guy near you that make custom subs- corey at spl audio- look him up in this forum and he can build you a custom driver that will destroy a xl for less money.
you looking for a spl sub or a daily or both?
so im guessing your not interested in the DP. theres a guy near you that make custom subs- corey at spl audio- look him up in this forum and he can build you a custom driver that will destroy a xl for less money. you looking for a spl sub or a daily or both?
I cant find any Thiele small parameters for the DP. Another thing is that with it being 1500 rms, I would need to get another to run off the mmats. Also if I were to run two, I would need them to be able to be wired to .5 ohms to power them. They really just don't fit my need, thanks tho. I saw SPL audio awhile back, and forgot about that option. I would be really interested in this, does he give the thiele small parameters of the subwoofers he makes?.. and how do I contact him?.. I thought he was pushed away from this board by vendors.
How's the condition of the amp? I live in Rochester, NY.. heading out of town here shortly for work.. I'll check up on the thread when I get to my hotel room..
Its in great condition, the only wear it has is a small part of where it says DC audio on the front is slightly worn in one spot. Besides that, the amp is mint. Purchased less than 6 months ago, work perfect. Never saw less than 1 ohm, never pushed or clipped. Sat in my room for half its life.
Interested in some sundown subs just reconed them 2 sa-8 v2 and 1 sd-2 12" also have 3 aq200.2 amps and a aq1200
Sorry im looking for cash or to add cash for a larger amp.
A Link would be very helpful. Id be interested in taking a look at some gear
116
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
246
Bwap
Bwap
NY
Below20hzonly
    Jun 3, 2024
