DC audio 2.0k
Bwap
NY
DC audio 2.0k
Bass knob with clipping indicator
DC audio 2.0k specifications:
Output Power (RMS) 4 ohm 14.4V 600W x 1
2 ohm 1,200W x 1
1 ohm 2,000W x 1
1 ohm@16v 2,500 x 1
Input Sensitivity 6V~0.2V
Low Pass Filter Switchable
( @ 24 dB Slope) Variable Hz 35~250
Subsonic Filter Switchable
( @ 24dB slope ) Variable Hz 10~50
Bass Boost Variable dB 0-9dB
Frequency Response Hz 15-270
Signal to Noise Ratio dB 100
Damping factor 150
Efficiency @ 4ohm % Over 90%
THD @ 4ohms Less than 0.1%
Fuse Rating 200 Amps
Linked Fuse Rating 400 Amps
Indicator Power Yes
Protection Yes
Clip Yes
Speaker & Power terminal Mold type power
Power Gauge size 0Ga
Heatsink Length inch/mm 17.72" / 450mm
Heatsink Width inch/mm 9.38"/238mm
Heatsink Height inch/mm 2.35"/59.6mm
Taking offers, not set on a price.
Will add for an mmats 3000.1 or 3000.05
Also add for a DC XL 15" or any quality 15" sub(s) that handle around 2k
For an estimate my zip code is 12053
are you near syracuse? are you familiar with TNESPL?
Havent heard of them, I am a little west of Albany in duanesburg. About 2 hours from Syracuse. Right now I have two dc lvl 3 15s.. running off this 2k.
I don't know what will beat that(researching a bit more), but im basically looking for something with a powerful motor.. debating buying an mmats 3000.05 and an xl with level 5 solf parts or carbon fiber option.. or maybe an aq hdc4.0.. idk yet minds racing on the new setup, im sure you know what I mean.
so im guessing your not interested in the DP. theres a guy near you that make custom subs- corey at spl audio- look him up in this forum and he can build you a custom driver that will destroy a xl for less money.
you looking for a spl sub or a daily or both?
so im guessing your not interested in the DP. theres a guy near you that make custom subs- corey at spl audio- look him up in this forum and he can build you a custom driver that will destroy a xl for less money. you looking for a spl sub or a daily or both?
I cant find any Thiele small parameters for the DP. Another thing is that with it being 1500 rms, I would need to get another to run off the mmats. Also if I were to run two, I would need them to be able to be wired to .5 ohms to power them. They really just don't fit my need, thanks tho. I saw SPL audio awhile back, and forgot about that option. I would be really interested in this, does he give the thiele small parameters of the subwoofers he makes?.. and how do I contact him?.. I thought he was pushed away from this board by vendors.
How's the condition of the amp? I live in Rochester, NY.. heading out of town here shortly for work.. I'll check up on the thread when I get to my hotel room..
Its in great condition, the only wear it has is a small part of where it says DC audio on the front is slightly worn in one spot. Besides that, the amp is mint. Purchased less than 6 months ago, work perfect. Never saw less than 1 ohm, never pushed or clipped. Sat in my room for half its life.
Bwap
Bwap
NY
Below20hzonly
michigan born
    May 14, 2026
michigan born
    May 14, 2026
