Dayton Titanic 12"
Titanic 1200 = Great Sub
I had one for quite a while in my car... these play LOW. And by low, I mean you can get an F3 of 30Hz sealed... which many subs barely get ported. It is also quite accurate for a woofer in it's price range, I really liked mine.
Down side... 3 ft^3 sealed per woofer box volume to get a good alignment. I did one in 1 ft^3 and the SQ was lacking... you could possibly go as low as 2 ft^3 stuffed with 3 lbs of polyfill if you have to.
It takes VERY little power to hit x-max with these drivers, I could get mine to x-max with 150-watts in 3 ft^3 sealed. This isn't bad... it's very efficient, but you have to be careful about bottoming it out with a large amp.
FYI, they 5 year warranty is great. Had a problem with mine once, had a new driver in my hands in about a week.
cough,I have no idea what u just said but sounds good to me
Right now, i found the following:
Dayton 1200 12"sub for $129 and
Dayton 1202 12" sub for $128.77.
Seems the prices just went up from last night at partsexpress.com
Which one or are there better ones for the money right now?
I don't have any experience with the 1202, but it has difference design goals. It won't go as low, but it requires a much smaller box than the 1200 does. Of course there is a reason they still make the 1200 Titanic, and that is because it is their "Audiophile" driver -- and I agree, it's a great sounding sub.
* Do you like massive low-end or do you prefer a flatter response?
1200 = massive low-end
1202 = flatter in-car response
* How much room to you have available?
1200 = large sealed box
1202 = smaller sealed box
* How much power do you have?
1200 = less power handling
1202 = more power handling
I'll have around 400w RMS for the sub. I guess i like a linear response- i'm guessing u mean balanced with proportion as the volume goes down and up instead of changing of "bassiness" with volume?
400 RMS is quite a bit for either sub, be careful with your gains.
By linear response I mean all frequencies having equal loudness. The Titanic 1200 will have a bump in frequency response really deep down... which most people tend to like. But many prefer a more linear response.
kevinsean23
kevinsean23
Fairchild, Air Force Base, WA
sundownz
