not much thump
Jay169
I was wondering what the problem is with my system. I have a 2002 F-250 Regular cab. Behind the seat are two audiobahn aw1006q ( 900 RMS each ), with an a1300hct pushing them ( 1200 RMS@ 1 ohm )
This I think would be more that enough in a truck, its not. The subs are in a sealed box ( I listen to mostly rock ) Is the box too big? it can't be lack of power. What is my problem? Thanks for any input on my situation.
The amp is the audiobahn A1300hct, I got the amp about a week ago. The box is .75ft per side from what the dealer tells me, not sure though. The amp should be OK as I have read the reviews, and I paid enough thats for sure ( got it from a dealer //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif ) I will try to swith the polarity on one sub to see if that helps. The dealer tells me to port the box, but I think its too small for that. I don't really know. Thanks
OK I tried to switch the polarity on one of the subs, it got worse
. I don't get it, I have tried everything I can think of. I have discovered that if I have the doors open the bass is good, but when I sit in the cab with the doors shut it dies. What could this be? What can I try? Thanks
try reversing the polarity on one of the subs. I'll need more info on the box.
You only reverse the polarity when you invert the subs.
My truck does the same thing, i think it has to do with the airspace inside the cabin itself. To help with this i ported my box(listed below). It increased the output but it's still much louder when i open the door, so i'm really not sure.
I was wondering what the problem is with my system. I have a 2002 F-250 Regular cab. Behind the seat are two audiobahn aw1006q ( 900 RMS each ), with an a1300hct pushing them ( 1200 RMS@ 1 ohm )This I think would be more that enough in a truck, its not. The subs are in a sealed box ( I listen to mostly rock ) Is the box too big? it can't be lack of power. What is my problem? Thanks for any input on my situation.
I don't think the box is going anywhere....
The door acts as a port, same on my car. You pick either new subs or new box...
Jay169
Jay169
New York
Jim Boom
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
