Dayton RSS265HO-4 vs UM10-22
  • 4
dennismv
56
Michigan
What is the difference between the two Dayton subs below?
  • Dayton Reference Series RSS265HO-4
  • Dayton Ultimax Series UM10-22
I am interested in building a system aimed for quality and thinking of having them be put into a sealed enclosure with 2 or 3 subs.
I note that one is high output and another one costs a bit more and looks bigger.  How do I decide which one is best for my application?
According to Dayton tech support, Reference is more musical, Ultimax focuses on low frequency applications, like home theaters, but both are good for home or audio.
Yes, that is correct. They can both be used in car or home application but they both have drastically different box requirements. The reference can stay very linear while being in a small enclosure and can take a bit more power. Very good choice for small spaces that you just simply can't fit a big box. The low frequency on this sub is not very efficient though so you need to port this sub in order to bring alive the lows, but even in a small sealed box, it can still hit frequencies from across the board effortlessly. The ultimax is a great sub that focuses on low frequencies but requires a much bigger box to do so, mainly used in home theater but I have seen these in cars as well. It's more efficient with power but would require atleast double the size box than the reference to make it sound the best. So I would ask myself.. how important is low frequency? How important is space?
The 8's have a frequency response of 40hz and up. So I would cross them over at 60hz and up. And crossover my subs at 80hz. That way I would get a...
Tuning as low as PE suggests will problematic (long port) unless you go with a passive radiator.
Pay attention to the width to height ratio of the port. The further you deviate from a square shape, the less efficient the port becomes and it...
Some people make to big of a deal about high voltage rcas. I had a pioneer head unit with smart sync ( 31 band eq, crossovers TA etc ). I replaced...
Ive been looking at amarican bass xd 1222 or 1244 ,and sundowns e series, they both seem very good , can't verify sound quality tho but I know...
37
9K
dennismv
dennismv
Michigan
THATpurpleKUSH
    Apr 28, 2024
    Apr 28, 2024
