danger ranger build
Awesome man, looks good.. Gonna probably be doing a good 142 outlaw and be vibrating a couple of coins in your cup holder. //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
you must be joking...
I got the first layer of deadner down, found a lace to run power and ground wire, and of course added some vinyl.
got the 3rd layer of deadner down tonight, power wires hidden, and routed the rca's.... tomorrow I will machine some dual inputs, and install the hu...
the place where the wires go through the floor is covered in foam on both sides and sealed very well.. there is only a slight hump under the carpet where the wires come through the floor, now their are 3 layers of deadener on the roof and the box is completely finished...
Looks like you need to sharpen your chisel for your sub cutout lol.Hurry up and get it playing.
like an idiot I didnt cut the hole before I glued the thing together so I had to use a sawzall to cut through the double baffle... lulz I need to find more cable lugs and buy my alt on thursday and then it will be done...
Are you planning on reusing the power pack? If yes cut the wires at the top red arrow only. Connect your new radio harness to the translucent one...
Agree with hispl. TC sounds soft parts were few and far between years ago. If you’re wanting to run two TC based subs you may be better off...
16
824
989
RangerDangerV2
RangerDangerV2
st cloud MN
RangerDangerV2
    May 12, 2024
Brendon Jenness
    May 11, 2024
