Cutting slanted side pieces
So, I've come to a problem while building my box. I need to cut these slanted side pieces, but I can't get a sure way to do it. I've got a chop saw, table saw, circular saw, and jigsaw readily available. I tried the chop saw and it isn't big enough to cut through the whole thing, even when I flip it around and cut the sides.
Here's the type of piece I'm talking about.
http://i245.photobucket.com/albums/gg46/gboxx1/TruckBox19cuft38hzslotportportsidel.png
Thanks for any help.
no way to cut angles with the table saw? if not does your jigsaw have an adjustable landing? the flat piece you sit on the wood. should be able to adjust that, and it should be labled with different degrees.
Yes, table saws do cut angles. It just has to have an adjustable setting for the blade. Ours does and it makes it a breeze //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
04PeeJay
04PeeJay
Shepherdsville, KY
bassman3
michigan born
    May 14, 2026
michigan born
    May 14, 2026
