cuts out at high volumes! HELP ASAP!
saywhat?
satx120, jealous?
okay, i wired up my HU and everytime i turn it up to about 60+ outta 80, it shuts off. is it just a defective unit or what? its hardwired by the way, and there was no way around that. and i dont want any of this "u shoulda taken it somewhere to be installed"
maybe it sensse strain on the speakers so it cuts out before you blow the speakers. Its an eclipse right. i had an eclipse unit that would shut them done sometimes. 60 is still pretty loud on that HU
well sound advice seems to think its voltage issues, but they hooked it up to some MB Quart Q's I WANT THEMM SOOOOOOOOO BAD such a sexy ass speaker sound quality wise, almost **** myself at the difference i c ould tell from my stock and those speakers. i couldnt talk almost. but he turned it completely up and it stayed on, and that was at 80 (max volume). so they are gunna reground my Head Unit when I get them to install it. that way if it goes out.......i get a new head unit.
Yeah I did remove the base cap and just straight wire you know grounded to amp and everything how it originally was before the base cap and it...
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
492
ringer ringer, chicken dinner... its your headunit. gotta upgrade mine as well, does the same thing, it cannot handle the additonal speakers, just...
Check your grounds! Both head unit and amp. I had this issue before and it was a grounding issue. Ground wire made enough contact to play low...
saywhat?
satx120, jealous?
saywhat?
H'Burg Mississippi!
BASS OUTLAW
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
