Custom Fiberglass Progress Thread: check it out
yes it is...should get rid of the rattle tho //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
so no comments on my new sander...//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif i love that thing
ya its an orbital sander //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
btw, UPDATE!
got 95% of the foam work done...drying as we speak...next will be to finish the vert walls and then fleece and begin to glass!
all teh foam i used
thanks for the posotives guys..today i will be getting ALOT done...gf, is outa town and no work //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif be checking back later 2nite for sum serious updates
UPDATE!
the last of the wood got glued togather and is going to be getting put in in less than an hour...
the cut is angleled to not get in the way of the amp rack once the boxes are fleeced...
ya, for sound deadening...it mostly just stops ratteling...here is a good explination of what the differences would be between using raamat/fatmat and expanding foam:
Fatmat and Rammat deaden by "mass loading" (adding weight to something) That weight alone is what you're using to lower the resonance of the panel. eg., a 1 oz piece of sheetmetal may buzz, whereas a 4 oz piece of sheetmetal the same size may not make a sound.
Remove and tap on the sidepanel on your computer case.
Tape a magazine to it
Now tap on it again - Notice the sound difference?
Great Stuff doesn't weigh a whole bunch, but if you can use it to add some pressure to the panel, the resistance will in fact deaden the natural resonance of the panel.
Like the magazine test above; Instead of using a magazine (fatmat), imagine pressing a big sponge to the other side of the panel. The sponge isn't gonna do much by itself, but with that pressure (since the foam expands) it works - even better, in some applications.
UPDATE!
STAGE 1 IS COMPLETE!!!! FINALLY!!!!
stage 1 includes: all teh wood work
i have all the wood work doen except for my rings...so on to the pics
the rest will be fleeced adn glassed
this is how much clereance i have on each side to mount a 15" ring...phew!
crazy4ozs
Banned
crazy4ozs
Decatur. IL
NaaN
