custom box help
Jerm1400
I built a box for two American Bass TNT 12's tuned to 33hz @ 4 cubic feet with .75 MDF. I have them on a little pioneer gm d8604.They probably are getting about 300 each. When I turn it up full tilt the box flexes at the top towards the center and I hear noise inside the box. I braced the box with 1.5 inch wood front to back & top to bottom. Can some tell me what's going on? I
Can you see it now?
Box dont look half bad. Not sure why you're flexing.How does the top panel of mdf fit?? Is it tight and even?
Thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif my first time. And it's tight but slightly uneven I cut the wood with a skill saw. But I'm confused //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif because it only flexes where the bracing is
Box actually does look pretty good especially for first time. I would maybe remove the wood bracing and buy some 1/2 inch all thread washers and nuts and use that for bracing instead. Run 2 top to bottom behind the subs and one width wise maybe even buy some 1 inch flat bar and tie it into the all thread that runs top to bottom to help with the flexing. One other pointer I would either carpet or paint the enclosure most woods are porous and this would help seal it.
Thanks. I have no air leaks I checked already it just flexes at the top where the middle brace is i'm going to try adding more bracing & see if that helps and which clue would be best to put carpet on the box?
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
5K
During my replacement of a factory sub I had my factory plastic enclosure just sitting in the back with my new sub just sitting in it loosely and...
If you're serious about an 18 in the trunk front firing/trunkwalled go ahead. At least you got electrical covered /w/ a 600rms sub I'd wager. If...
16
Jerm1400
Jerm1400
Orlando, FL
Jerm1400
