custom box help
Jerm1400
I built a box for two American Bass TNT 12's tuned to 33hz @ 4 cubic feet with .75 MDF. I have them on a little pioneer gm d8604.They probably are getting about 300 each. When I turn it up full tilt the box flexes at the top towards the center and I hear noise inside the box. I braced the box with 1.5 inch wood front to back & top to bottom. Can some tell me what's going on? I
mail
I braced it from front to back and top to bottom with 1.5 wood and I used spax screws
is it slot ported or aeroport either way that is what I would suspect. either the wood comprising your slot port is vibrating or the aeroport is.
it's a slot port 4 cubic feet tuned to 33hz with 16 cubic feet of port area
Hey dude, I wanna see this box. I got my second TNT and I about ready to build my ported box. Don't forget to make a YouTube vid.
I still cant see the links maybe its me? 1.5 inch wood shouldn't flex only instance I can think is maybe you split the wood when driving the screw?
one of them did split the wood but only a small piece it has two other screws holding it down. The caulk around looks cracked and when I pull on it it really doesn't move.
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
5K
During my replacement of a factory sub I had my factory plastic enclosure just sitting in the back with my new sub just sitting in it loosely and...
If you're serious about an 18 in the trunk front firing/trunkwalled go ahead. At least you got electrical covered /w/ a 600rms sub I'd wager. If...
16
Jerm1400
Jerm1400
Orlando, FL
Jerm1400
