Current Draw Help
cappleton3
I just installed a new system in my truck and I am getting some pretty significant headlight dimming. I have a Kenwood 621 amp driving four 6 x 8's and a Kenwood 811D driving a single Brahma 12". The 621 says it is pulling 6 amps and the 811 says it is pulling 30 amps at full tilt.
Should I be seeing headlight dimming with a draw of 36 amps? I just ordered a red top Optima battery as the factory battery is now 4 years old. Does all of this add up? Will I need to do the Big 3 upgrade? I thought for sure the 811 was pulling more than 30 amps giving the headlight dimming I have but according to the amp, it is not.
The amplifier has a display on top that shows temperature, fan speed, voltage and current draw. It looks like it takes a snapshot of current draw once per second. Obviously it is not spot on accurate given it is only a snap shot reading but the most I have seen over the span of 5-minutes or so was 30 amps on the 811. I have 4 gauge power feeding the amp so I don't think it is starving for power.
Well disregard my previous post, I'm an idiot. I assumed that Late Night Tip would be the song to pull the most current and I was wrong. I put in one of my favorites, RUSH-Limelight and saw a peak draw of 74 amps on my sub amplifier. That would explain my headlight dimming. I think my stock alternator is like 60 amps but am trying to find out.
I just ordered an Optima battery about 3 hours ago but now doubt that will fix my probalem. I will likely need a new alternator. Thanks for the tips.
If you want max current draw (warning, you can blow fuses this way) is a test tone track or bass track. Heck, if you are a rush fan maybe Subdivisions would do it too (there is that one part they hit the synth that goes kinda low).
Juan
cappleton3
cappleton3
Alabama
OldOneEye
