CSB Telecom battery?
TnT_Sounds
profiling gets **** done!
I have encountered quite a few pallets of these batteries and I have yet to find any type of use for them from car audio users so anyone know?
The model number is HRL 12330
They rest right around 13.2-13.5v.
On the CSB site I had seen it says 33A maximum charging limit:confused: I'm guessing that per cell?
http://www.csb-battery.com/english/01_product/02_detail.php?fid=8&pid=37
well If i read there site right I would say that the only thing that this would be good for in car audio would be doing burps or using them in a large battery bank. They have a max discharge of 800 amps for 5 sec as well as they have a relatively low internal resistance. The down side is they don't recommend charging with more then 33 amps. So either you could do burbs with it and not have it hooked to an alt but to a charger that is less then 33 amps or you can run them in a bank and make sure that there is enough of them so that when hooked to the alt and the max output of your alt when divided by the number of bats is equal to or less then 33 amps. or at least that is my take on it.
TnT_Sounds
TnT_Sounds
Colorado
93dakota
