crunch amp gets hot
GRANDPA
i have a crunch 1100 watt powerzone amp and i have 2 mtx terminators hooked to it and the amp gets real hot and cuts off the subs but if i reset the amp it does okay. is the thermal protection cutting the subs off or what? and if it is is there a way i can keep the amp cooler?
1. What is the model number of your amp?
2. What is the impedance of your subs (DVC, 2-Ohms, DVC 4-Ohms, SVC 4-Ohms....)?
3. Are they wired stereo or mono bridged?
4. How are the coils wired (Parallel, Series, parallel/series....)
Answers to these questions will likely lead to the problem and solution.
You can also call 847 540-7700 and ask for tech support.
If a Powerzone is running hot, there is a reason that can be attributed.
well the powerzone series are kind of a piece of junk
I had one and it did pretty good.It's one 2 15" L7's and it beats,no overheating.
To the op,I think the powerzones are AB class and get hotter than D class,check your install also your subs wiring.
GRANDPA
GRANDPA
Richmond VA
Mr.Ronin_2U
michigan born
    May 14, 2026
michigan born
    May 14, 2026
