Get a 200rms amp and tune it down to 120rms. good/bad idea ?
Engine_hp
Hi guys,
would it be a good idea to buy a 200rms x 4 @ 4ohm and tune it down to putout 120rms x 4 @ 4ohm ? Will that hert sound quality ?
adv/dis-adv
adv:
1) u can use it for future upgrades,
2) bang for bucks (some of them are)
dis-adv:
dont have any
tell me what u think.
thanks
that amp is 200x4 at like 15k hz to 16k hz, lol
most amp manuf do not follow the real guide lines for output they only give you a power raiding at a set range 'which they have set for there amps'
a true 200x4 amp like say a $2000 arc audio will be 200x4 over any range so alot of variables to picking an amp ussaly the more output they claim and the cheaper the amp is the worse the amp is overall //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
as for power id take a 500x2 amp over a 50x2 amp anyday for a 60w rms set of mids
you get more range as others have said
you get cleaner ouput capabilitys
and alot more options on top of those //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i LOVE this advice,
HELP me find a 150+ rms @4ohm.
i love the alpine 150x4, but what i dont like about it is that it puts the same amout of power @ 2ohm.
the alpine is very nice yes they give same output at 2phms and 4 but most alpine amps in that series can do alittle more than the stated voltage they should have 'birth sheets' that state there lab tested outputs.
if you want a nice amp that is 4 channel but rocks at 4 ohms and gives more at 2ohms
http://www.woofersetc.com/p130/GT42--Boston-Acoustics-4-Ch-700-Watt-Amplifier.htm
•4-Channel High Current Amplifier
•2 Ohm Mono Stable
•Advanced cooling allows varied mounting positions
•Adjustable feet for varied mounting surfaces
•Screw-down security cover protects tuning controls
•Terminals accept bare heavy-gauge wire
•Adjustable input sensitivity: 0.2 - 5 V
•Variable High-Pass Crossover: 20 - 350 Hz (12 dB/Oct)
•Variable Low-Pass Crossover: 50 - 350 Hz (24 / 12 dB/Oct)
•Variable Q Control: 0.7 - 1.2
•Power and Safe LEDs
•Recessed RCA Inputs allow clearance for tight mounting locations
•Optional subwoofer level control not included
•Dimensions: 22" L x 9" W x 2-1/2" H
•RMS Power Rating:
•14.4VDC:
•100 watts x 4 chan. @ 4 ohms
•150 watts x 4 chan. @ 2 ohms
•300 watts x 2 chan. @ 4 ohms
•450 watts x 2 chan. @ 2 ohms
•12.6VDC:
•75 watts x 4 chan. @ 4 ohms
•120 watts x 4 chan. @ 2 ohms
•220 watts x 2 chan. @ 4 ohms
•350 watts x 2 chan. @ 2 ohms
alittle more than your other amp you where looking at but these amps are monsters
they are old model of there series so big discount all over but I have a few and they are realy clean amps //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
btw they are 22in long so very big / long so dont fit in some installs easy
Engine_hp
Engine_hp
Middle East.
mmouse57
