Critique the Box
The general rule of thumb for port area is 12-16 sqin. per cubic foot. You have 1 cube, so you need 12 - 16 sqin. of port. With a 1.75" wide port, you have roughly 19 in^2 of port area -- which isn't necessarily a bad thing. Ideally for smaller boxes you want to keep the port ratio to 1:8. The minimum port width I would do with a port that's 10.5" tall is ~1.25".
So, 1.5" would be ideal = 15.75 in^2
I have never messed with that idea. Not sure if I want to after doing a quick read. Above my pay grade and skill level. //content.invisioncic.com/y282845/emoticons/redface.gif.62fdbfe1a101588a808c4cff71bcb942.gif
Just expensive. Buy one of the TC sounds ones from Parts express and you can add and remove mass in guess and test fashion until you acheive desired tuning.
My have to play with that idea. On a one month staycation, so I will be wasting a lot of time in the tool shed.
You can also try playing around with an aero port if you want. The problem with small boxes is the port takes up a ton of space compared to the actual box size itself which is why most people end up doing an external port.
Do nt go by general rules of port area, because they do not take into consideration power requirements or port velocity (indirect parameter). There are two possible errors with lowering port area.
1. Increased potential of port noise
2. Decreased efficiency and coupling capabilities
So, if you want to challenge yourself with those two possible factors of decreasing port area, make sure you know what you are dealing with as far as power. A balance between the two needs to be met to get the most out of the design if you do not plan to increase dimensional volume.
In this scenario, the ideal layout is great that you have. Just have to make sure it works in all aspects of the design.
I can tell visually right now, that it was correct to say the port may be quite long. BUT this can also increase the low output NOT FROM TUNING, but from correct phasing. SO, in reality, if you want more out of a design, (listen up all), do not give port area a limitation, and do not give port length a limitation UNLESS you are limited physically in dimensions and space. Then those factors need more controlled attention.
I will. I will build the slot vent first, then play with other ideas.... including the aero and passive radiator.
Here is where I am with the 1.5" port width
It is 35.25" port length. I am going to have to block the inside a bit to get the cubes back down to 1.
Do nt go by general rules of port area, because they do not take into consideration power requirements or port velocity (indirect parameter). There are two possible errors with lowering port area. 1. Increased potential of port noise
No one can make this easy for an occasional hobbyist, ha!
Just for shitz-n-gigglz, what if I wanted a dual slot port for the 1cu. (Just for the look) A slot on left and right sides of the woofer. Is there a way to figure that with no more or less than a 1.5" x 10.5" slot dimension for each port? Or would the ports be so long as to make the enclosure too huge for a measly 1cu?
The woofer is only going to have 400w (rms rating) going to it.
I would remove that little piece at the end of the port and just extend that back piece so it's 1.5" from the side. That small of a difference in length isn't going to yield much audible difference, and it's just a pain if anything
Yeah Jason way to make shit complex //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Don't worry your design is better than anything I could make by myself.
acreature
Mach1smo
acreature
The most eastern of the US coast
acreature
NorthFramingham
    Jun 30, 2026
