Critique the Box
Overall Dimensions:
(w)23-5/8" x (h)12" x (d)14-3/4"
1 cu ft for Diamond Audio D310D4
46-1/8" port length @ 2"x10.5"
Should be tuned between 32-33hz
Close? Or no cigar?
1cu ft
I figured the cu ft plus driver displacement, then calculated the port at 2" wide x 10.5 tall, and worked the port around the original 1cu ft box.
I wanted a wider slot (2") than the 1.5". The 1.5" had me at about 33-36 inches in length. Can't recall exactly, but the narrower the slot, the shorter the port.
Hope I am not confusing.
Per the 12volt "Slot Port Length Calculator":
port width @ 2", port height @ 10.5", box cu ft @ 1, @ 33hz = 48 inches of port.
Per carstereo "Calculate Your Vent Length":
Same specs as above = 47 inches of port.
I could not get WinISD to save what specs I had for the D310D4, so didn't use it.
edit, just saw that you saw, ha!
He said 1 cube.I don't like a port with that many bends in it, but whatever. Should function better than prefab.
Agreed.
I didn't want to risk a smaller width port and gain port noise. At 1.5", I would still have at least two corners. Unless I widened the box and lessened the depth, I see no alternative.
Ideas?
The general rule of thumb for port area is 12-16 sqin. per cubic foot. You have 1 cube, so you need 12 - 16 sqin. of port. With a 1.75" wide port, you have roughly 19 in^2 of port area -- which isn't necessarily a bad thing. Ideally for smaller boxes you want to keep the port ratio to 1:8. The minimum port width I would do with a port that's 10.5" tall is ~1.25".
acreature
Mach1smo
acreature
The most eastern of the US coast
acreature
