cool I will do it nowyo its like one dem volume thingyes, jest crank dat sht up foo.
lol. no but seriously there is no way of knowing without a dmm for sure. It will depend on your particular equipment. If you have a 3000 watt amp on a 300 watt sub, obviously halfway is going to be too much. But if your amp and sub are fairly close in specs, then i would imagine halfway would be ok. You should be able to hear the difference when it clips.cool I will do it now
it also depends on the pre-out voltage on your HU also. The higher it is, the less you have to crank up that gain.lol. no but seriously there is no way of knowing without a dmm for sure. It will depend on your particular equipment. If you have a 3000 watt amp on a 300 watt sub, obviously halfway is going to be too much. But if your amp and sub are fairly close in specs, then i would imagine halfway would be ok. You should be able to hear the difference when it clips.
Lol out of 5 years I took a 4 year break.Have you ever learned or read anything during your 5 years on this site?!?!?
nG
