crackling sound????
yuegling2982
jeep member
THIS IS MY SET UP
1 10in RF T110D4
hooked up to a mono MTX thunder 250(251D)
My KENWOOD 6/9s are on either side of the sub set 5-6in behind the sub
each 6/9s and sub have seperate boxs
this is all in the back of a 93 jeep wrangler
THIS IS MY PROBLEM
ever once in a while the sub rattles not all the time. almost like a crackling sound. its not the audio but the way it hits every once in a while.
could it be the box its in?
any help would be great. :boobies:
SUB-http://www.rockfordfosgate.com/products/ez2rockford/ModelInfo/ModelInfo.asp?ItemKey=10063574&CategoryDesc=Power%20Subwoofers
AMP-http://www.mtxaudio.com/caraudio/products/amplifiers/roadThunder251D.cfm
you sure its the box? maybe its your trunk rattling. When the sub hits a certain frequency it can cause ur trunk to resonate or something like that. You could try to put some Sound deadening all over your trunk. It should remove rattles and cause your sound to be louder and such. You could try it and see if it removed the "crackling" sound
yuegling2982
jeep member
yuegling2982
Lancaster,pa
yuegling2982
