cracked, what happens?
i wouldnt buy it the motor strengh wont be they same i dont believe it will perform near as well as it should when you have cracks like that theres n/s poles everywhere causing it to fight itself in a probable end result in it falling apart
like i said just wrap it in ductape to keep it from falling off. wrap it tightly
or if it is not yours ask the seller to do that before shipping cause it will def get worse in shipping.
probably cracked from the heat as the voice coils fried... //content.invisioncic.com/y282845/emoticons/redface.gif.62fdbfe1a101588a808c4cff71bcb942.gif
For the record that magnet would have magnetic poles that look more like this:
N
ll
S
N
ll
S
That or when it was shipped to the seller, and that is why his top assembly "failed":rolleyes:
It doesnt matter the direction of the polarity. As of right now, its proboboly N & S in just about every direction you could imagine. Tell the seller to remove the top assembly from his other 5200 and try it on there first. I could be wrong. It could still work. Im just going off what i learned in science class.
it wont work as well as if the magnet was in one piece, once the magnet is cracked like that, it builds magnetic waves in different direction, and not like it was designed. so you loose magnetic force.the top and bottom plate may still be able to re-direct the magnetic waves towards the gap, but how knows, i would not buy a sub like that, but as long as it works, just use it till it dies. use some crazy glue type adhesive to keep the magnet from coming apart.
Glad they stepped up and replaced it! I honestly would have thought it was super petty if they didn’t just swap it out for you still being under...
pioneerpimp
pioneerpimp
IL
PowerNaudio
Decebal
    Jun 10, 2024
