Covered amps with Plexi Pics!
DFW40
had an amp design that way back in the day that i helped a bud do. we eneded up inverting 2 ppi art amps with the water cooling kit ppi sold for those amps. amazing setup when you add uv reflective dye and blacklights. to bad he got rear ended and the water busted lol.
Would have been even better if you exposed the guts... Looks good though... Hows it sound.
it sounds terrible. //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
and when i get all my stuff and finish the install i will pwn him //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
ok so it actually sounds really nice and looks just as good.
i am wondering if the amps will like being closed off like that?
did you put in a fan or something.
~Magick_Man~
x3
especially since they are different series amps one is a d5 and the other isnt.
with them inverted/exposed you couldnt tell they are different.
but if not it looks plenty good the way it is.
~Magick_Man~
edit: oh, and get a different grill //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
i hate those fishman grills
Tried to wire in fans but they drew too much current from the remote, I need to wire in one of those things that will let it run off my main large power cable but also tell it when to come on......whatever those things are called??? Suprisingly the amps do not really get that hot because they have a half inch above them and all the sides are wide open and the false floor has a small gap around it so it gets somewhat fresh air but I would feel better with the fans. I know that everyone hates the fishman grills but they leave large room for excursion and completely protect the sub when I have junk in the trunk since this is my work car. I also go a new EQ Magicman so watch out.
Tried to wire in fans but they drew too much current from the remote, I need to wire in one of those things that will let it run off my main large power cable but also tell it when to come on......whatever those things are called??? ........
Relay
i had one hooked up when i ran some fans fo rmy amp.
easy to do. especially with the plug/base that the relay plugs into. (djman37 FTW...)
and your puny EQ doesnt scare me.
i will crush you //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
~Magick_Man~
DFW40
DFW40
Keller, TX DFW area
DFW40
vegang
vegang
