coustic design reference
Thanks,i thought it might be a 510 but there were a few different models also and they all kind of looked the same... Are these amps under rated? 1 ohm stable?I saw the specs somewhere and it said it will do 1100@ 1 ohm but now i cant find them again but im not sure if the were actual specs or not..
yea mine has a 30 and a 25 for some reason..
That is probably what the prior owner had handy at the time.... If you buy enough used gear, you will see that improper fusing is a common thing... Sadly, most tend to OVER fuse versus using a smaller than required fuse.
sancho20
sancho20
tampa bay ,florida
gunz4me2
vegang
vegang
