Couple of questions
Yeah I'm going yo try for 4 alts. And 8 agm batts. Im probably going to bust my budget though so if that happens I'll probably have to grab some PPI900.4s instead of Alphard sound 4 channels
Do not forget to consider all that weight: batteries, subs, amps, WOOD. It all adds up and will destroy your vehical suspension and strain your engine. 4 alts will definitely bog down your engine.
If you can just do two good alts, and then do a seriously strong battery bank, you might be better off than trying to run 4 alts and a few batts. You can always sit at idle and charge between demos. Try to budget in some suspension upgrades or extra parts because I see shit breaking in your future.
I disagree.... Alt power over huge battery bank anyday. I have quad alts. Best thing I ever done eletrical wise. Having 4 alts doesn't bog down your engine unless your hammering full tilt... But a huge battery bank will deff add stress the whole time. I'd rather have a 15lbs alternator making 350amps then a 80lb battery holding 110amps... I'd rather make power then store it.
I see your point. Its all good. I am just going off my few years competing. It really depends on a case by case basis.
I talked to Kevin at juicebox and for two black cherries and a 60ah lithium will run me around $2700 and I figured if I can get like 3 350 amp alts it should hold nicely. What do you guys think?
dailyrider123
dailyrider123
under the sun
dailyrider123
