spnkysprky
Member of the Old School
Ok,I have a couple of questions.Ok,Im a High voltage Electrician and In my line of work one way to find amperage (when giving at least 2 factors of the equation)is dividing the Total wattage by the volts...So I assume its the same in DC voltage....Then given these factors in my vehicle.I have a total of 1500watts im using(maybe less,Im doing worst scenario).Dividing that with 14.4Volts gives me a total of 104.2AMPS.
Is this the correct way to figure the amperage?I was guessing I could use a 160amp alt???yes or no
If so.....then will my factory (Dodge truck)136amp alternator be enough (I have the basic truck with no extras)to Supply my needs So long as I upgrade the big 3(wire size,Deep cycle battery maybe caps)....are there other factors I should be aware of?
I was thinking not all electrical systems would be exactly 14.4 volts...closer to 13.8 or less so I was thinking to use 12.6 volts instead.My 1 amp is 63% efficient total 995watts RMS and I will add another at 500rms approximate same efficiency.
Im putting it here in this section for better response.
This is their Take...look at MDC http://answers.yahoo.com/question/index;_ylt=AsINmeX5NFQ.wUhUVTUF2fzsy6IX;_ylv=3?qid=20080110211714AAdr8Cv
