Raisedin305
Banned
OK so im more than likely going to be powering in the future some thing like two HCCA D5000s or some thing of that amount of power.
My electrical consist currently of two optima yellow tops (starter and for audio)
stock alt- 130 amps
So far I have been able to set the gains on the amp to power 2500rms @ 1ohm but my voltage drops very low, around 12.3 volts at idle and if I rev the engine it goes around 13.0volts, this is with a stock 130amp alternator. When I was at idle with no music on or nothing it was at 14.2v
My question is...if I was to run two orion 2500ds with two optima yellow tops and a 200amp alternator, will I be fine or will I need a bigger alt?
IMO, I say it isn't enough but some people disagree.
stock alt- 130 amps
