could my electrical be a reason why my L7 isnt so loud?
reed dollaz
i notice people do the big3, add batteries, etc, when they are pulling alot of current and alot of watts. usually, lights dimming, etc... well im only using one 10" l7 and maybe 500 watts and my lights dim like a mother ****er. headlights, tail lights, interior lights, everything flickers when my bass hits. could this be a poor electrical system, or just bad power/ground?
I'd try the big 3 first. I did it to my 99 firebird. The stock alt is 105 amps. When i put my bass amp by itself, the lights didn't dim to bad. Then I put a kx600.4 next to it and it had a big voltage drop. I did the 2 steps of the big 3 w/ 1/0 welding lead wire and it helped it out a great bit. I'd say do that and see what happens.
Do the big 3. Check all your connections, especially your grounds. Bad connections are hell. Also check that your battery is in good condition.
If all else fails it's probably time for a beefier alt!
yes to all the above
check battery
check connections first, easiest thing to do
big 3 after that if everythings good, its the next cheapest thing
theres no reason you should need a bigger alt for 500 watts... but who knows??? electrical systems are weird
You have 500 watts going to a 10" sub did you expect to be breaking windows or something? Stop all the stupid posts and just get a new setup that is louder and hopefully you stop crying like a little baby. //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif :crying: //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
P.S. I have an 10" L7 getting 600 watts and I know it ain't shit but it is all I need for now until I can afford bigger.
reed dollaz
reed dollaz
Ocala, FL
spoonraker
