InfinitePeace
I've been debating this in another thread with a few people and I can see the point of both sides to some degree, but it does look as though a fuse would not have helped in this instance. Of note is that the alternator manufacturer recommended against fusing the line between the battery and alternator. I personally hate this part of car audio, I hate electicity and it's something I've never been inclined to really wrap my head around which is why while I get the concepts, I'm having it 100% professionally done so that I don't screw something up, eventhough it sounds simple. Despite how fuses are helpful, I believe that from what I've read, a fuse in this situation would be superfulous in addition to the fact that the manufacturer of the alternator gave me about a 20 min spiel on why NOT to fuse this cable and why to use a smaller gauge wire than the rest; I was advised specifically to use as big a cable as I wanted for the other 2, but to use only 4 awg for a 180a alternator in addition to the stock wiring because the binding posts are too small for a 1/0 size wire.
Now, that said, not that I'm accusing the OP of doing anything sloppy, but is it possible that my last comment and that fact might be a contributing factor? Since the wire was too large, it heated up on the small binding post (per what Ohio Gen said would happen) and then the metal became malleable and just slowly bent with the taut cable and eventually made slight contact and arced? Taking a stab in the dark, but just trying to use what I've learned from the people that make the alternators.
