Connect 4 channels of an 8 channel amp to a sub?
Mattt9998
CarAudio.com Newbie
Ny
Hello, and thank you in advance,
I am putting a buget system in my boat that consists of the following…
Fusion head unit
4 Skar audio 6.5 speakers
Rockville RXM8BTW 8 Channel 1500 Watt Marine/Boat Amplifier
  • RMS Power Output at 4 Ohms: 65 Watts x 8 Channels CEA Rated
  • RMS Power Output at 2 Ohms: 95 Watts x 8 Channels
  • RMS Bridged Power Output at 4 Ohms: 190 Watts x 4 Channels
  • Peak Bridged Power Output at 4 Ohms: 380 Watts x 4 Channels.
  • Configurable to 8-6-4 channels or 6.1 or 4.2 System
Rockville MS12LW 12” free air sub
My question is can I bridge 4 channels to the sub? Connect 2 sets of wires to the sub? The other 4 channels would run the 4 Skar audio full range speakers.
if you have a 4ohm dvc sub you can bridge 4 channels into 2 and use each of the 2 bridged channels to each voice coil. play a test tone and make sure the voltages are exactly matched per bridged channel
Mattt9998
CarAudio.com Newbie
Mattt9998
Ny
staan
