Is this just on alpine units, or have you heard of any others that are like this??Alpine head units - sub level is attenuation only. set gains at preferred listening level. i like shooting for sub level 6-8 for gains. then you can increase or decrease based on the recording or personal tastes.
i usually adjust sub level with each album.
I'd like to know about the sub level on the excelon models. I set my amp with it at +15db to try and get the best possible voltage out of the rca's.... Am I wrong?Alpine head units - sub level is attenuation only. set gains at preferred listening level. i like shooting for sub level 6-8 for gains. then you can increase or decrease based on the recording or personal tastes.
Isn't there a possibility of a clipped signal or at least distorted if you turn the sub level all the way to +15 to set your gains? Isn't it sort of the same thing as setting your gains with the head unit volume on max?I'd like to know about the sub level on the excelon models. I set my amp with it at +15db to try and get the best possible voltage out of the rca's.... Am I wrong?
That's what I'm trying to find out.Isn't there a possibility of a clipped signal or at least distorted if you turn the sub level all the way to +15 to set your gains? Isn't it sort of the same thing as setting your gains with the head unit volume on max?
I would just compromise and set the gains with the sub level at +10, that way you can still get higher voltage and eliminate any possibility of distortion/clipping. I might do it this way once I switch up my system and have to reset my gains.That's what I'm trying to find out.
I've been thinking about doing exactly that.I would just compromise and set the gains with the sub level at +10, that way you can still get higher voltage and eliminate any possibility of distortion/clipping. I might do it this way once I switch up my system and have to reset my gains.
agreed. the head unit manual should say if the adjustment is an EQ boost and it should tell at what frequency the boost is at.You folks are confusing bass level with attenuation. Some headunits have a bass attenuation setting that allows you to alter preout voltages. All headunits have a bass level. Alpines for example have the attenuation setting. That should be set at 15 to get the max preout voltage from the headunit. The bass level hower is different and should be set at 0. Altering the attenuation setting does nothing to introduce clipping, altering the bass level does.
