Confused on Amp Setup.....Next choice to make
  • 1
Hello Forum......
I'm currently trying to come up with the best solution for my problem regarding my amp speaker set-up.....
My Car is a 2010 Mazda 5.
-Stock Stereo
-Polk Audio db571 (Front)
-Stock Speakers (Rear)
-Lightning Audio 4 Channel Amp
-RF P2 10" Sub
Currently everything is hooked up via a LOC and everything seems to be 2 Channels (Front). This was installed at Best Buy (I Know I know)......
Here is my problem......
I had all of this same equp in my previous car and I had Front Channels for Speakers, Rear Channels bridged to the sub......Worked great!!! If I needed less bass, I would Fade away from the rear......The Sub is so loud in the hatchback, I dont need rear speakers.
Now it's opposite...To get less Bass, I fade to the rear but lost the front speakers........
I guess I have a couple of options here:
1-Get a new deck with 3 sets of preouts and dedicate one of the "2 Channels" to the sub-out. the other "2 Channels" to the front speakers.
2-Get a new amp with some sort of "Bass Control" where I can change the bass on the fly......
Thats the point of this long post.......I need to control my bass better.....Some songs it's perfect and others its overwhelming.........
So frustrated and confused.....
HELP =)
It looks like you have the wrong connections. The head unit uses one amplifier to amplify 2 to 4 of your speakers. You are using 2 amplifiers...
Yes. I do not fully understand the question, but if the manufacturer suggests such a big port, it is probably because it has a high QTS. If it...
Dayuuum!! LOL. Going CHEAP sometimes doesnt pay..LOL 💩 💩
13
Hey guys I'm new here I'd like first and foremost that I'm not greenhorn but I haven't been an installer for 10+ years either. So the issue I am...
Thank you, I did check the ground and and fuse holder wires and everthing is fine. All I did was swap amps and the previous Alpine pdx sounded...
86
RunDougRun
RunDougRun
Quartz Hill, CA
RunDougRun
