Bennieficial
I'm a little confused about impedance matching. I'm going to provide links of everything so you can see specs of everything. I have a (Rockford Fosgate P10001-bd) amp. My spec sheet says that actual power is 553 x 1 @4 Ohms, 968 x 1 @2 Ohms, and 1449 x 1 @ 1 ohm. I was planning on getting 2 12" Alpine Type-R's, which has dual voice coil. But my question is, should I get the 2 Ohm version (SWR-1223D) or the 4 ohm version (SWR-1243D) of the sub for the most power? And how would I wire the two subs with my amp for the most power, from the diagrams below?
2 x 2 Ohm Diagrams
2 x 4 Ohm Diagrams
Also, would it sound better to run 2 Alpine Type R's or 2 Alpine Type X's with my amp? Or would the Type X's be underpowered?
2 x 2 Ohm Diagrams
2 x 4 Ohm Diagrams
