confused about balanced input amps
I was stating the configuration, not asking. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif. FYI
Heck I'm not even smart enough to know it wasn't a question.
The only advantage is high signal and low amp gain, to minimize noise.
Yep. One thing I should not have to worry about is noise. I think the stinger expert series rca cables are some of the best and then the 8v balanced outputs, I should be good on that end of things.
I have made my own balanced converters, using audio-grade op amps and 1% resistors, it's a pretty easy concept. At the transmitter/source the pin is as-is and the shield signal is inverted 180deg. Then the receiver inverts the shield signal, sums the two, and you get a 3dB signal gain. A second benefit is any noise common and in-phase on both wires, i.e. induced in the run, is cancelled. I was getting an 80dB noise reduction with my version. Balanced does nothing to reduce noise inherent in the source or amplifier.
So, you built a balanced line driver? One RCA in and two out? Cool. Got a schematic?
In summary, you can feed high-level inputs on some amps with you balanced outputs.
I thought about that too, but the 16V output in balanced mode is actually higher than a standard HU speaker output.
not really, the HU output is "balanced" and 16V peak-to-peak is achievable. Regardless, you'll only make that voltage out of the HU with test tones at full volume. Under normal conditions, using high level inputs would be fine. the kicker is what to do with the shields. i don't have a good answer for that, without accessing signal ground on the PCB directly.
say you put 16v to an amps' input section that adjusts down to 6v, will it hurt the amp? I always thought the excess was sort of "dissipated"..am I wrong?
Specs on the OP's Eclipse say 8 VRMS per preout, 16V balanced. That's about 45V pk-pk
Not sure what you mean.. in balanced mode you don't need them.
This is an extreme case.. the normal mode of operation would only be 8V. Having high input signal probably won't "hurt" anything, you'll just overdrive the amp and have no control of your output level.
your math is off. Vp = Sqrt(2) * Vrms
16V rms is around 22V p-p
My xtant amps accept 18V rms inputs.
you want a signal ground to carry through whenever possible. XLR cables have 3 conductors for that reason. it really depends on the type of amplifier inputs.
your math is off. Vp = Sqrt(2) * Vrms 16V rms is around 22V p-p
22.6V peak, 45V p-p. Picky, picky, I know... still above the typical 14V p-p HU speaker level.
Assuming differential inputs, I would think the chassis ground at the preout RCA's connectors would suffice. Some pro audio gear has a switch to disconnect that ground, in the event of ground loop. I'd be inclined to tie the shield of a twisted shielded pair to chassis at the source end and leave the amp end disconnected.
Well if I wasn't confused enough before, I sure am now. //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
My Pioneer Premier HU has a ground wire from the rca section that ties it's self back to the chassis and the tag states it is to ground the shield side of the rca outs to prevent ground loops. It is my understanding that differential inputs do the same thing inside the amplifier chassis in the input section....is this like what you describe?
You are correct.
I agree. I think it will be a case-by-case basis. Amps can have different input section topology and handle noise differently.
husker77
husker77
Nebraska
quackhead
