conecting 1/2" mdf to a metal trunk??
  • 2
buthatsabuick
OKC
how in the world would i got about connecting mdf to a metal wall of a trunk so that its steady and wont come loose,//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
1. screws.
2. silicone (I heard someone recommend this, and I'm thinking that it just might work. Easy to apply, you can always cut it out later if need be, cheap)
3. Make your own pivoting MDF arm to hang onto the many different holes within the trunk confines. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
is screwin in to the trunk dangerous like for the outside panels? if the wood is .5" thick what size screws do you think?
cars usually have two sheets with space in-between (hence the pain in the arse when damping) so as long as your screws aren't like 6" in length, a 1" would suffice.
DO apply damping mats in-between the metal and MDF to minimise rattling. If no damping mat, at least SOMETHING to absorb the vibrations, such as sponge or something...
Damn, those Brickhouse subs are beefy! 4" coil and big power? Yes please!
10
just use riv-nuts or clip-nuts, made for blind fastening. some window weld should hold the ring on there pretty good..... being 4x6, you could...
4
I say go for it. Just add some kind of bracing to the bigger panels. Some old home speaker boxes were made of 3/8" mdf. Maybe not even mdf, some...
Yea. That's what I did. I mixed the glue with the dust from sanding and fill in the bigger holes. Then filled the rest with wood filler..works awesome
9
3K
buthatsabuick
buthatsabuick
OKC
paikiah
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
