Computer setup help needed...
j3bus2k3
Si vis pacem, para bellum
As soom of you know I built the a TB8 sub for my copmuter. I also have a cheap-o pair of $50 Sony 5.25" Bookshelfs with a 3/4" tweeter. I have the filer on the sub set at around 80 and God knows the Sony's cant play down to 80hz. I was thinking of utilizing the low/high level inputs to make use of my plate amps 125hz filter for the bookshelfs but then I have an open range from 125hz down to 80hz...? Should I invest in a new set of bookshelfs or build a center with 2 6.5" woofers and 2 1" tweeters? Mind you this is just a computer/dorm setup, not HT.
Also...this is a retarded question but I'm curious. If a receiver as a single sub-out and your plate as a stereo in, is there any loss by just using the right channel? I.E. instead of using a y-splitter to utilize both plugs on the plates input?
well if your receiver is an LFE out and you have it connected to your plate amp, is your plate amp repoccessing the sound from the receiver(trying to answer a question with a question). If your receiver has stereo RCA outs, use those, otherwise try to turn the LFE off on your receiver and get a $5 y-splitter for the RCA's or just use the mono(some manufacter's of plate amps reccomend diff things). As far as your original question... Get new bookshelfs. The 80-100somthin gap is most likely the least of your worry's with those sony's. Also there really isn't a gap there, since both are crossed over at those points, so your still getting volume at that "gap", it's just a significant dip in volume.
j3bus2k3
j3bus2k3
St. Pete, FL
jacko
vegang
vegang
