componet woofer hiss
  • 3
91XR-7sled
I decided to amp my components individually, ex. 1st channel left tweeter, 2nd channel right tweeter, 3rd channel left woofer, 4th channel right woofer. In order for me to do this i had to bypass my crossover. The system sounded real good, loud and clear. Then i began to play with the gain setting on my amp, my tweeters blew up, just stopped working. My woofers still work. I just ordered a new set of tweeters and seperate crossovers, so when they come in i can wire my system the way i want without blowing them again. Right now i just have my woofers hooked up to the amp and running through its original crossover. When i turn the volume up, i hear a hissing sound from the woofers when it plays a certain frequency. Does this mean they are blown as well or is it a wiring mistake or does the crossover on the amp need to be properly set? Thanks for your help!
The woofer to a good component set will sound blown if the tweeter is missing. I can't hear the speaker, but odds are it needs the tweeter again. You may also be sending each speaker too much power in your setup.
that is an Ideal crossover and designed for use in an home type loudspeaker. A simple Linkwitz-riley 2-way is easy enough/ The tweeter wire lead...
36
Those subs are 400w RMS each, and that dual enclosure is 800w RMS with a 2ohm load. That's a 4ch amp that does 55w x 4 @ 4ohm, & 75w x 4 @ 2ohm...
837
  • Locked
Looks familiar: https://www.caraudio.com/threads/who-needs-new-equipment.613325/ Wouldn't that be a real kick in the ass. I shared that so...
7
And dont skimp on the Sql...that doesnt mean it dont get loud,that just means it sounds great while getting loud lol
4
Well yes, I've searched cruthfield many times, I just wanted input from actual people to go off of instead of numbers and prices. I've got it...
6
91XR-7sled
91XR-7sled
Langhorne, PA
JaJay721
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
