components wattage - HELP!
Isuzu95
Just wanted to know what amp would suit my 5-1/4 Clarion components (2 pairs). Each pair is 170 watts max.
I'm debating over the Rockford Fosgate 301x and the 501x.... The wattage on the 301x is 42.5 RMS x 4, and for the 501x, 65 RMS x 4 watts.
Would the 301x be enough or is it worth the money to go with the 501x.
I'm picking an amp up SOON and I need help //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Thanks,
Imran
Sorry, got my facts wrong.. the 301x is 37 watts RMS x4, and I believe my components can handle 45 RMS per speaker (each mid range w/tweeter).
You still think 301x will give me the full power from the components??
Thanks, but the price wasn't really an issue, cuz my friend is hooking me up. There's only a $60 (CAD) difference between the 301x and 501x... YOu think i should just go with the 501x then??
Are you sure your comps only gets 45 rms, and its a 170 watt max? If i were you ill get the 501x, u said money is not an issue, get the zapco 360 50x4, very clean amp.
That's what i'm not too sure about.. Each pair of components say 170 max.. Wouldn't you divide that by two (for each component), then by two again to get the RMS. Is that about right???
Also, I need to rephrase myself... Money is an issue, but since I'm getting a deal on either amp, the price difference is not a major deal, IF my components will sound a bit better..
Thanks
Thanks for your help... I think i'll go with the 501x then...
My deck does have 4 volt pre-outs so i will turn the gains down.... And do I have the wattage right then on the speakers?? Each pair of components = 170w max, each speaker (mid + tweet) = 85 max = 42.5 RMS???
Also, do the new Fosgate amps heat up or shut off (due to heat) after being on long periods of time (but not being pushed too hard)???
Thanks!
I came across those too. Seen all the drivers out on the alibaba sight for sure. Wonder who is making them for PPI? Looked long and hard at those...
28
In the $600 range I like my stereo integrity speakers so far Tm65 midbass $399 m25 tweeters $199
What are some of the louder, while still sounding good, 6.5" sets out there? Been looking at some of these higher powered Sky High Car Audio sets...
Hell... Run It!! If it sounds good to you. Then that is what matters the most.. Your OWN EARS.
Isuzu95
Isuzu95
Toronto, Ontario
Isuzu95
SPLBassJunkie
    May 21, 2024
    May 20, 2024
