components and clipping
  • 4
Originally posted by joshpoints I was wondering if the crossover box that components come with block out clipped signals. I noticed that when I had my amp set-up with the low pass crossover on THe components put out no sound, so I was wondering if they would not put out sound if a clipped signal was sent to them.
xovers merely cutoff requencies, if I know anything at all...
components would mean it's mid and tweeter.. that's not low pass. THey will cut out low signals..
now, your amp with lowpass... that means it's only sending low signals...
amp(low signal)---->xover(highpass)
see the diagram on top. There's nothing that the speaker is getting because you've put lowpass on the amp. Put it at high pass... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by paikiah xovers merely cutoff requencies, if I know anything at all...
Couldn't they cut out the dc current waves that occur when clipping exists through a crossover? I would think that someone could create a crossover that eliminated flat waves, which I believe is what clipping is.
Originally posted by joshpoints Couldn't they cut out the dc current waves that occur when clipping exists through a crossover? I would think that someone could create a crossover that eliminated flat waves, which I believe is what clipping is.
hmm, I don't know about that one..I only know the basics... //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Resistors and inductors aren't that intelligent...
And there is no DC current in a clipped wave, it's still AC...
Remember- to a speaker it's just a signal, it doesn't care either which way.
But JBL sent the following statement to me about clipping when I had a problem blowing subs with an amp that I had.
Because of this your amplifier is clipping very early since it is trying to reproduce a power level it cannot product because of the impedance load and then it delivers DC distortion to the woofers. DC distortion is what actually damages the voice coil of the woofer causing the woofer either to over throw and hold or just over heat the voice coil and the weakest link in the circuit (the tinsel leads) would then fail.
clipping may act like DC current at the peak part (long straight line..) , but its still AC.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by joshpoints But JBL sent the following statement to me about clipping when I had a problem blowing subs with an amp that I had.
A giant load of crap.
Clipping will not overthrow a woofer- it's a brick wall for the amplifier. It won't make the cone go any further than it would have in the first place.
I came across those too. Seen all the drivers out on the alibaba sight for sure. Wonder who is making them for PPI? Looked long and hard at those...
28
In the $600 range I like my stereo integrity speakers so far Tm65 midbass $399 m25 tweeters $199
What are some of the louder, while still sounding good, 6.5" sets out there? Been looking at some of these higher powered Sky High Car Audio sets...
Hell... Run It!! If it sounds good to you. Then that is what matters the most.. Your OWN EARS.
joshpoints
joshpoints
San Ma Tonga Central, CA
jlaine
    May 31, 2024
    May 24, 2024
