component wiring need help!
papito
FL
so my crossovers INPUT side has both + and - for the woofer and tweeter.....
so how would i wire this, to a bridged 4 ch amp? most components just have one + and - input, while this one has 2....is that cause it's supposed to be ran active? Should i just use my 4 ch amp by hooking up 2 channels to the tweeter inputs on the Xover, and 2 other channels to the woofer inputs on the Xover?
you can kind of see it in this pic, this is what the "IN" side looks like...the out is the same, but thats pretty straight forward to wire.
it has a by amp capability just hook up the input through the woofer input and there should be a pin inside the xover that you need to change it's around the attenuation pins you want it on the one that does not say byamp.
ok so im just going to do that, hope nothing gets ****ed up.
also, about mounting them, my car only has 1 hole to mount up a speaker b/c stock ones use a harness....would i be OK mounting these up with 1 screw up top? how else would I do it?
papito
papito
FL
Phoenix Risen
